Thanks a LOT ! its working now, only complains about dead nodes and ROI above recommended settings ( see attached files with list of evemon silent nodes). Is there a workaround to save calibration parameters?
invalid node error during connect to camera in Spectrum Analyser
Re: invalid node error during connect to camera in Spectrum Analyser
- live.png (17.84 KiB) Viewed 294312 times
- roi.png (52.95 KiB) Viewed 294312 times
- nodes1.png (53.05 KiB) Viewed 294312 times
Not at the moment unfortunately. They also changed the way to access camera data and that's why you are getting the error with the UserDefinedValues thing.
I found an example in the SDK on how to write data to BFS cameras and I evaluate it's about ~1 day job. Problem is I have plenty of things that are currently more urgent and my brain has some difficulty with coding since my burnout.
If you can find a good programmer who is willing to contribute to the project (and who has access to the camera) I'll be happy to share pointers on how to update the code.
It's also worth to correct the other silent errors like pixel endianness but that you can also force in the spinview software directly.
automatic_jack
@Luc, have you found either the time or assistance to create another update?
If not, I might be available to help. I have one of the FLIR Blackfly S cameras, and even with the patched pointgrey.dll I am not able to attach to the device.
- error_log.err.gz
- (73.46 KiB) Downloaded 14190 times
Jack which folder did you put the patch into? It needs to go bin64 not bin. You'll still get a user defined values error but you can click through it and it will still work
automatic_jack
When I trace the code execution, it's loading the patched dll, so its location is not the issue.
Okay.. sounds good. Yeah I was getting errors too when I tried it but then I realized I was putting in the bin and not bin64 folder.
Can you post what version of Spinnaker SDK you are running, what exact camera model you have, whether you are using the ethernet or usb-3, and your version of windows and architecture?
I'll check tomorrow afternoon. I already put a remainder on my phone to borrow a BFS camera for the test (I don't own one myself).automatic_jack wrote: Tue May 30, 2023 2:50 pm @Luc, have you found either the time or assistance to create another update?
automatic_jack
Spinnaker 2.0.0.147 (x64)andy wrote: Tue May 30, 2023 4:59 pm Can you post what version of Spinnaker SDK you are running, what exact camera model you have, whether you are using the ethernet or usb-3, and your version of windows and architecture?
FLIR Blackfly S BFS-U3-31S4M (S/N 22614269)
This is a USB3 camera, and it seems like the patched dll is to fix issues with the GigE version.
The host system is Microsoft Windows 11 Pro build 10.0.22621 on an x64-based PC. The HAL version is 10.0.22621.1413.
Okay weird, yeah I have the exact same setup and it worked for me. I used the usb-3 as well. I will say I copied every file in from that zip into bin64, replacing the dll when I did so. Not sure if it matters.
One more thing I thought of, when you install Spinnaker, I selected "developer". There was an option, selected by default, just installs spin view. Another thing is I used the usb-3 cord from flir, but unlikely that matters.
