Camera Not Detected
BowenZheng
Camera Not Detected
Post by BowenZheng »
I bought a BFLY-PGE-31S4M/C-C 1/1.8" Blackfly® PoE GigE Monochrome Camera https://www.edmundoptics.com/p/bfly-pge ... mera/3875/, but I'm having trouble connecting the camera to the Spectrum Analyzer software even though it connects to Spinnaker IDK. I was going through the manual to resolve it, but I can't figure out why the camera is still not detected.
Re: Camera Not Detected
Hi,
Can you double check the followings ?
  • is the spinview software closed when you try to connect to the camera using SpectrumAnalyzer?
  • is the ip address of the camera in the valid range ?
If it keeps blocking we can organize a TeamViewer session.
BowenZheng
How do I determine if the IP address of the camera is in the valid range? I can identify the IP address, but could you clarify what the valid range is supposed to be?
Thank you,
Can you open spinview and take a screenshot of the camera list ? without doing anything else
BowenZheng
Sorry for the late reply, but the OpenRaman software is now successfully running when I close the spinnaker software. However, when I go back to try to use the spinnaker software, it's saying that another application is running it. Is there a way to bypass this and use both applications simultaneously? Image.
Thank you,
Hi,
That's normal -- you cannot connect twice to the camera
It's a common problem people meet but there is nothing to do, it's just that the camera is not made to support multiple connections.
Dubbie
Post by Dubbie »
I am also having trouble. I have the same camera, I can connect and capture just fine in spinview, but when I run the spectrum analyser app, It just crashes. Is it because I have spinaker v4 installed and not v2? Should I try to build your app against V4 of the SDK?
you need to use the exact version provided with the software or recompile for the new SDK version
Dubbie
Post by Dubbie »
Ok, I am back on this project.
I have installed the correct version of the spinaker SDK as per your download link.
The camera shows up and works fine in spinview.
However I can't seem to get it to work in the openRaman app. When I click connect, it shows the camera, but if I try to connect, I get an "invalid node" error. I can't figure out where this is coming from. I don't have spinview running at the same time.
Here is the even monitor log.
Screenshot 2025-11-29 192009.png (59.12 KiB) Viewed 276502 times
I guess you are using the BFS and not the BFLY version of the camera ; the problem was already addressed here : viewtopic.php?t=15
there's a dll to download to fix the issue :)
